Can not set "Remove Panel" to "No" for dynamic VI
In the VI Settings tab of the Application Builder, has no row for my dynamic VI. How to add this row for my dynamic VI.
(2,820 Views)
Are you sure that you added the dynamic VI on the Source File tab? I can't reproduce the problem where the dynamic VI doesn't show up in the VI Settings but it is possible that you can't set Remove Panel because of settings in VI Properties.
(2,820 Views)
I am in agreement with Dennis. I am using LabVIEW 7.1 and I had to trouble setting "VI Settings" on dynamic VIs.
(2,820 Views)
