Can not view "Properties"
Accepted by topic author seeminus
I like 7.1 its a very stable versionSmiley Wink. Reinstall the LabVIEW,if u have some time.
Message Edited by Baji on 06-10-2009 10:01 AM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 11 of 12
(539 Views)
Ok ... did a re-install ... and it's up and showing properties by the dozen Smiley Happy .... Thank you to everyone.  I had a hunch that re-installing would do the trick ... but I wanted to know if it just wasn't something within the code that I had never seen before.  Thank you all for your /replies.
Message 12 of 12
(520 Views)
