Can perl script execute VI from w/o LabVIEW GUI?
For my application w/ Linux, I would like to write a few VIs and then have a perl script orchestrate the whole project and call the VIs from the command-line.
Is there a way to call LabVIEW from the cmdline so I can execute a VI w/o having to boot the GUI?
Thanks for your help,
-Sean Harre
(2,950 Views)
Hi Sean,
To execute a VI from the command line you can first build it into an executable using the Application Builder.  Then you can call the executable from the command line.
Allen
www.weekleyconsulting.com
(2,941 Views)
