Can read TEDS in MAX but not with DAQmx VIs
I have a cdaq 9181 with a 9234 accelerometer module.  I have 3 teds equipped accelerometers connected to ai0, ai1, and ai2 repectively.  In MAX, when I reserve the chassis I can read all three teds, no errors.  When I do the same thing in labview (ie reserve the chassis, create a daqmx task, associate teds data with each physical channel, all with daqmx VIs) I can only read two out of three teds.  The third one throws a "no teds sensor detected" error.  This code has been in use for about four months now, though I just rewrote the calling VIs, and hasn't displayed this problem.  I've attached a snippet of the task building VI for reference.
Any ideas what's going on?
Thanks.
Using LV2012 and MAX 5.3.1 running on Windows 7 32 bit.
CLAD
(2,937 Views)
returns Device 0 chanel 1-3 not chanel 0-2
make the one a zero
(2,927 Views)
Nope.  That's a delete from array, length 1, index 3.
In any case, I eliminated that block since the string array wired to the for loop controls how many devices the VI attempts to configure.  Same result, verified it was trying to configure ai2.  Here's the updated snippet:
CLAD
(2,924 Views)
Well I found part of the problem...the transducer I couldn't read had a damaged cable.  That still doesn't explain how MAX was able to read it though.
CLAD
(2,889 Views)
