Can sliders control points on a XY Graph - Please help.
Good morning LabView Forum,
The aim here is to have eight sliders (Vertical Fill Slide) to control the positions of 4 points on a graph. I want the graph to control a stepper motor's Ramp Up, Move and ramp Down.
It is very easy to see I'm just starting out with LabView, so my ideas could be a bit off and could point in the wrong direction. I'm trying. I'm an artist so it makes sense.
Currently, I'm changing a working system where a simple Knob is used to control a Graph and the motor. This works well and the Slew control does its stuff! An image of the .VI is below.
As always I will attach the files.
Please help.
M
(4,502 Views)
I worked it out eventually. Lots of YouTube watching. I'm learning.
(4,466 Views)
Hey there,
I see you seemed to have worked it out. I'm unsure how you went about it, but I thought I'd put up an example of how I would have done it from your initial image. If you build the slider values in to the two arrays for X and Y values that will allow you to control each point individually.
Hope this helps!
Nic
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(4,425 Views)
Hello Nic,
Thanks for the help!
I am learning slowly. It is hard when you don't know something and 20 helpers come along and they tell you 10 other things you don't know or understand. ;o). It takes time to piece everything together.
I would like to see your VI file, but it's for a later version. I'm on 2014 home student.
I am making good progress and want to learn more.
I got this working by taking bits from other topics and stitching them together.
Please keep helping! I am 54 now and learning is slower.
(4,423 Views)
Apologies!
I took a stab and saved it for 2015, wasn't quite enough. Here it is for 2014.
Nic
Nico
Systems Engineer
(4,421 Views)
Yes! That is what I was trying to do.
I will work with that and play!
Many thanks again!
M
(4,418 Views)
Happy to help.
Always come back if you have further questions.
Nic
If a response answers your question, it's good to mark it as a Solution, it helps others find the answers faster as well 🙂
Nico
Systems Engineer
(4,415 Views)
