Can somebody fix my corrupted subvi, error "Fatal Internal Error" "objheap.cpp"
I have been strugling to open this file after a reboot due to not responding computer. The file is a part a larger library however, this is the part that is not responding and giving "Fatal Internal Error" "objheap.cpp" .
Does anyone know how to fix this issue or how to repair this file.
I am using a LabView 2012.
Thank you for your time.
(2,564 Views)
Hi obarriel,
that could be a tricky job as LV2013 claims "block diagram can't be opened"!
Meanwhile you should learn two things:
- using LLBs isn't recommend practice nowadays (atleast not for storing daily work VIs)
- make a backup of your works on a regular basis (using SVN/GIT is recommended too…)
(2,559 Views)
