Can somebody help me find out where the problem in my Vi is?
hello everybody,
may be here is someone who can say me why the fomula node in my Vi doesn't work!
thanks!
(2,717 Views)
As the error message states, you have an error in your exponent expression. In two separate places in the first expression, you are using ** with no value. For example, it should be x**y to take x to the y power. You have something like x**.
(2,710 Views)
oh thanks,
that is exactly my problem, I'm still a beginner in using labview, for that reason sometimes there are so little problems but for me they take alot of time to solve. I read that one uses ** for exponation so i understood that x** means x power to 2, x*** means power to 3!
Thanks you again!
best regards
gnurt
(2,697 Views)
