11-16-2009 09:30 AM
Hey,
I was wondering if someone could convert this 9.0 VI to version 8.6. I would be very grateful if you could.
Solved! Go to Solution.
11-16-2009 09:35 AM
11-16-2009 09:37 AM
Thanks so much!
This topic can be closed now.
11-16-2009 09:43 AM
sravankb wrote:This topic can be closed now.
You can do this by clicking on the solution button. Click on "Options" menu located on the top right corner of Mathan's post and select "Mark this as solution". Then this can be closed. ![]()
Also don't forget to give kudos ![]()
