Can someone help me stream data to/from HDSIO that is larger than the onboard memory?
I have a PXI-6541 that I'm trying to use to capture data from 1 line of a 1Mhz data bus.  I need to record the data for about 10 seconds with a software trigger.  Once the data is recorded, I need to be able to play back the data in a continious loop.  I have attached the files I'm using.  The "Stream to HWS.vi" seems to be working.  I have attached it along with the vi that I tried to play it back with.  I'm getting an error that says "You cannot write data outside the boundaries of your waveform.Make sure you are not trying to write more data than your waveform can accommodate and that your write location and write offset are set correctly."
Please help!
Jason
(2,455 Views)
I made a playback vi similar to the capture.  It seems to be writing something to the hardware but i'm not getting any data out.
(2,447 Views)
My apologies that we didn't respond to this forum post sooner. Do you still need assistance with this issue?
Kareem W.
Web Product Manager
(2,384 Views)
