Can someone please explain to me how to make "tab control" an enum item?
Thank you Mr. Altenbach! I'm successfully able to change the tabs programmatically. I just did not know I had to place the tab control inside the loop. Thanks for the suggestion. I think it works as expected now (see attached VI). Also, big thanks for the event structure suggestion and great explanation how to set it up.
Message 11 of 18
(1,146 Views)
Isn't it frustrating when what you tell the code to do and what you want the code to do don't match?  Hopefully with experience, the two converge more quickly (but it's not guaranteed).  😄
Bill
CLD
(Mid-Level minion.)
Message 12 of 18
(1,137 Views)
Yes, that's one of the most frustrating things ever. 😄
Message 13 of 18
(1,129 Views)
Hi GCRK,
Well, then you forgot to pray the daily mantra of "THINK DATAFLOW!" before starting to code! 🙂
Message 14 of 18
(1,123 Views)
Some 15 years down the road that still happens surprisingly often. 🙂
(aren't all bugs a case of this?)
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 18
(1,112 Views)
You mind is playing tricks on you...
Former Certified LabVIEW Developer (CLD)
Message 16 of 18
(1,096 Views)
You still have way too much unnecessary code!
  • The sequence structure after the loop (and its contents!) can be deleted. Since you initialize the shift register, the tab will start on the correct page when you run it. The page in edit mode is irrelevant.
  • A 1000 ms wait is way too long for an interactive program.
  • "OK" is the default for the dialog. No need to wire it.
  • Dialog popups are annoying in general.
  • The output of a one button dialog is always the same, so the "select" is pointless.
  • Don't label it "tab control 2" if it is not a control, but an indicator.
  • The local variable in the "page 2" case is unnecessary. The tab will get written a ns later anyway. There is no need for any local variables anywhere!
  • Your code gets stuck on page 3 because there is no way to continue except press the stop button. The "move to next page" button is no longer functional! That's not nice to the user.
  • A switch is not natural for latch mechanical action. Use a button instead.
Here are some quick modifications.
Message 17 of 18
(1,085 Views)
Thanks Mr. Altenbach! These are definitely important points to take into account. See I just don't want my code to be functional. I also want my code to look like code from a pro  and work efficiently taking into CPU usage and stuff. Thank you for this!
Message 18 of 18
(1,036 Views)
