Can someone please help me autosize the columns on my table using labview? I already built my table; I just need to autosize the columns.
I tried Activex, but couldn't figure how to implement it in my code. Can someone please help?
I attached a VI and the excel file (TDMS)
(2,886 Views)
Nothing attached.
This task will be difficult because it depends on the font style and size. If you know the maximum length of a column (because the contents are no more than a certain number of characters), I think it would be easier to just set the column width that way.
aputman
(2,865 Views)
I just read a post about a function called "Get Text Rect".  This may help you get the size, in pixels, of a string of characters.  Then you can use that to set the column width.
https://forums.ni.com/t5/LabVIEW/How-do-you-autosize-column-widths-in-a-multicolumn-listbox/td-p/318...
aputman
(2,853 Views)
That of course is the right answer!
Jean-Pierre was one of my early LV mentors.
Ben
(2,811 Views)
