Can someone please help me to open my existing labview file? I am getting this error. Thanks
Have you tried any of the steps listed here - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P70sSAC&l=en-US
Are you using some kind of source control that could be causing an issue? Attach you VI and maybe a member can work their magic on it.
(1,527 Views)
Hi ani,
as you didn't provide any code at all nobody else than you can try to open this VI…
(1,525 Views)
I also see you are trying to use a 64-bit version of LabVIEW.  That may cause issues with a lot of toolkits that were never ported to 64-bit.  Trying using a 32-bit version of LabVIEW.
(1,513 Views)
