Can someone provide a small sub panel example
Can someone provide a small sub panel example that recieves a number from the Top vi does some minor math in the sub panel vi and returns the answer to teh Top vi?
I ask because I am not having much luck on finding out how to do this type of operation.
Thanks in advacne
Tim C.
1:30 Seconds ARRRGHHH!!!! I want my popcorn NOW! Isn't there anything faster than a microwave!
(3,265 Views)
Hi Tim C.,
why can´t you do this operation in a normal sub vi? See the attached (fast and short) example please.
Hope it helps.
Mike
(3,257 Views)
I wanted to make a "Plug In" type architecure so I can make future VIs that will all accept the same inputs from the top VI (usually will be an array of numbers from a csv file) but perform different math functions.
The sub panel did not seem to be updating the result in the example.
Tim C.
(3,253 Views)
OOpss it works, I tried running it from the web at first....
Thanks for your help on this
Tim C.
(3,252 Views)
