Can someone show me how to get the data from this vi into four columns in a spreadsheet file.
I believe the issue is being caused by my numerical data, 1-D array of dbl waveform (double(64-bit real(~15 digit precision))). I believe it has to do with the conversion of this data that is causing my headaches. I alleviated all of the vi except for raw data using numeric constants in place of the 1-d array of dbl waveform and was able to get the result I wanted by simply using the convert into string vi. However I cannot use the convert into string vi. with the 1-d array of dbl waveform, the only way I know to convert this to a string is using the array to spreadsheet string vi. which is giving me the undesired results. Does this make sense to anyone and if so do you have any ideas on getting around this? Thanks.
Message 11 of 15
(731 Views)
I think this is what you may be looking for.
Message 12 of 15
(727 Views)
I can't see it, I have labview 8.2.
Message 13 of 15
(722 Views)
Please forgive my forgetfulness. Here's the 8.2 version.
Message 14 of 15
(709 Views)
Accepted by topic author BWMPDINC
No problem. Thanks everyone for your help. I found out that the only thing I needed to do was replace the "Array to Spradsheet String" vi with "Number to Fractional String" vi and that fixed everything. According to NI Software Engineer the "Array to Spreadsheet String" vi appends a new line to the end of the output string and that is why I was getting data in multiple rows. Like I said I really do appreciate all the help.
Message 15 of 15
(693 Views)
