Can someone tell me if Write JPEG File does a Flush File.vi call?
I've got an application that writes a JPEG file to a USB drive and want to ensure that the USB is not corrupted when the user removes the drive.  This is an embedded application so I can't instruct user to "safely remove" the drive and I'm trying to find a simple solution that does not necessarily involve registery work.  Any ideas?
(2,220 Views)
That VI is password protected, but the BMP version is not so based on that one I'd guess no.  Unless I am mistaken, closing a file has the same effect of writing all buffers to the disk so I think you are safe in that regard.
(2,216 Views)
