Can't Add or Edit Items in CombBox in Design or Runtime
In LabView 2010, I can not add or Edit Items in ComboBox Control in either Design time or Runtime even though Allow Undefined Strings feature is enabled.
Edit Items Box is alwys grayed out in Design mode.
Down arrow next to Combo Box is always grayed out.
I can not have more than 1 item in ComboBox Control.
How can I add multiple items to the ComboBox at Design and Runtime?
Message 1 of 8
(4,878 Views)
at runtime you have to use property node
right click on combo box in design panel -> create property node-> item
change to input then you can connect an array of string .
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 2 of 8
(4,870 Views)
If I have the Allow Undefined Strings feature enabled, shouldn't the User be able to add strings?
Why can't I Edit Items at Design time?
Message 3 of 8
(4,864 Views)
thing i don't understand :
how do you see the radio buton "allow undefined string" if you are saying you cannot add item in design panel ?
if you right clik on combox does properties enable, can you then reach edit items tab ?
Message 4 of 8
(4,859 Views)
If I go to my ComboBox control on FP, right click and choose "Allow Undefined Strings" on pop-up menu. There is no radio button.
With or without this feature enabled, I still can't edit items in ComboBox, the table is grayed out.
Are you talking about some other control?
Message 5 of 8
(4,853 Views)
this option had no relation about editing items or not , i hadn't notice it was accessible true pop up
when you rigt click is properties disable also ?
may be i 'm wrong i talking about that :
see attachement
Message 6 of 8
(4,849 Views)
Perhaps you can attach a short video describing what you are seeing?  http://www.showmewhatswrong.com/
Are you using a type def control?
As mentioned earlier, selecting "Allow undefined strings" doesn't determine whether you can edit items in your combo box.  It only sets whether you can input other string not in that list.
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
Message 7 of 8
(4,814 Views)
Accepted by topic author dbaechtel
I'm not seeing the issues at this moment.
Restarting my CPU and LV must have fixed a temporary condition.
THANKS.
Message 8 of 8
(4,806 Views)
