Can't Connect to Network Stream in startup.rtexe
I have encountered a rather frustrating issue. I have developed an architecture that depends on network streams to connect my RT application (hosted on a cRIO) to several windows clients. Everything worked seamlessly when I was running the RT Host VI from my Labview project. However, when I tried to deploy the RT application as a startup vi on the cRIO (as startup.rtexe). I could no longer establish a connection to the nettwork streams.
I have tried adjusting the context name of the network stream path to "startup.rtexe", but this did not help.
Can anybody help me?
THANKS!
(3,023 Views)
Hi RyanEwart,
Do you get some error code or a error message?
Carmen C.
(2,989 Views)
I've been meaning to post my results. The error actually entered the chain prior to the Network Streams. It boiled down to a rookie mistake:
Don't use 'Value' Property nodes in a real-time application! When the RT application is deployed, no front panel is loaded and these type of property nodes will error.
Thanks!
(2,985 Views)
Hi RyanEwart,
I'm glad to hear that this is already solved!
Best,
Carmen C.
(2,982 Views)
