Can't Find Package to install
Hello All,
I can't seem to find the package I'm missing to get the RIO to activate on LabVIEW 2016. Can anyone help me out?
Thank you so much!
(2,206 Views)
My initial guess would be the FPGA module. Either it's not installed, not licenced, or failed install.
Kind regards
LabVIEW Fairy
cRIO Enthusiast
Please mark solutions when appropriate.
(2,101 Views)
Does it show up in MAX?  If it does, can you expand both its "Devices and Interfaces" and "Software" tabs to see something that looks "reasonable"?  [You should also look to see that the right-hand pane is populated, including showing a reasonable-looking Firmware version].
Bob Schor
(2,082 Views)
Looks like you have the FPGA module (IP Integration and other stuff is showing up) but are missing device drivers - CompactRIO
(2,065 Views)
