Can't Set Fill Option
Right-click the yellow slider; set the fill option to "Fill to minimum".  No problem.
Try that on the cyan slider and LabVIEW crashes.
What I am trying to accomplish:
I have 4 values that are being set automatically and I want them plotted on a chart.
I also want the user to be able to override the auto setting of any of the 4 values.
My idea was to customize the waveform chart, replacing the digital displays with vertical pointer slides.
It's functional, but I can't make it as pretty as I want.
(1,601 Views)
Can't help, but can confirm crash. Not just the Cyan Slider, any slider other than the first one (closest to the plot). Win10 LabVIEW 2020 SP1, 64Bit
(1,568 Views)
Turns out that using property nodes to make the changes works.
The bug seems to be in the way LV handles mouse-clicks on any but the 1st digital display; somehow the reference to that item gets lost.
(1,548 Views)
