Can't Size ListBox on Front Panel to Display only One Item
I am trying to size a ListBox Control on my Fron Panel to only Display 1 Item at a time. The smallest I can make it is about 1 and 3/4 lines.
The ListBox is to display a list of Customers, from which only 1 can be selected. It will be confusing if more than 1 is displayed.
How can this be done?
(2,768 Views)
Accepted by topic author dbaechtel
I found the solution in the Properties.
Thanks.
(2,757 Views)
It can be done by changing the number of Rows to 1 in the property of the List box.. Is that what you wanted or anything else...
Smiley Wink
(2,750 Views)
