Can't Unbundle By Name slider
It works in LabVIEW 7.1
-Kumar.B
Message 11 of 15
(669 Views)
No, it doesn't work. It has the same behavior like the other versions.
Message 12 of 15
(388 Views)
Hi eaguirre,
Because the behaviour is intended and there never was a need to change it.
Why don't you use Altenbachs 10+ year old suggestion to give labels to the slider data?
When you attach an image next time you should consider cropping it to the relevant part. No need to show a mostly empty frontpanel that was maximized to screen…
Message 13 of 15
(375 Views)
Kudo this idea if you want NI to improve sliders to unbundle by name: https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Naming-Slide-Meter-Gauge-control-clusters/idi-p/12860...
Message 14 of 15
(359 Views)
@altenbach wrote:
Well, the sliders don't have names. I don't really see the need.
A benefit is when multiple sliders have been added to the object and you only want to set one. Otherwise, all others must be wired between Unbundle to Bundle.
Message 15 of 15
(330 Views)
