Can't acces VI due to VI settings
I set the VI up to run on open and then I have it exit LabView with the press of a button. Tools bars are shut off as well, no run button no abort button. So obviously, I am having a problem being able to open the VI for modification. Is there some way to reset the VI properties??
(2,762 Views)
Drag the icon of the VI into the block diagram of another VI.
Ctrl-double click it to open the block diagram.
Ben
(2,759 Views)
Drop the VI onto the diagram of a new blank VI as though it were a subVI.  Then click on it to open it from the diagram.  It will open in edit mode rather than run mode.
Lynn
(2,757 Views)
Accepted by topic author Charles.Bryan
Thank you for the reply.
I was able to access the VI by stopping one of its sub-VIs, now I can access the VI properties. I thought I was going to have to re-write!!
(2,755 Views)
