Can't add cRIO-9053 to NXG 5.0 project
I'd like to try programming a cRIO-9053 using LabVIEW NXG 5.0.  I installed software using MAX, then attempted to add the system to my project using SystemDesigner.  It is not discovered, so I try to add hardware by address.  Here's the result:  Screen Shot 2020-06-25 at 11.08.16 PM.pngan error stating that NI Systems Management Service is not installed or running on the machine.
Any ideas?
(3,203 Views)
NI CompactRIO 20.0, RT/FPGA definitely installed?
Regards
Jono
(3,173 Views)
Hi Jono - Thanks for the quick reply.  Yes I believe I have those necessary items installed.
(3,159 Views)
Accepted by topic author kinnikinnick
Turns out using the repair feature of NI Package Manager didn't fix it.  But a fresh install in the following order did:
LabVIEW NXG
NXG RT
NXG FPGA
CompactRIO drivers, NI-VISA, NI-Serial
(3,100 Views)
Ahh, that’ll do it! I wish it would force install in the order IDE, Modules, drivers.
always think repair is a bit of a waste of time, as much as I hate reinstalling, sometimes a necessity.
hope it’s pain free from here on 🙂
Cheers
Jono
(3,093 Views)
