Can't buil my installer--Labview2015
I can build exe.When i buil installer,the build was unsuccessful.The error message is "The following product(s) are not found on the system or have been upgraded".无标题.png无标题1.png
(2,790 Views)
Hi qingge,
the installer files for the mentioned components are either missing or replaced because you installed an upgrade…
Have you been able to create an installer for this project sometime before? When it worked in the past, but not nowadays: what have you changed in between?
(2,781 Views)
Hi GerdW,
   I have not create an installer before.The is the first installer after i installed Labview2015.
   I have try to  repaired Labview ,but it also does't work.
   If the products have been upgraded,how can i uninstall these products and reinstall them?
   Thanks for your help .
(2,776 Views)
