Can't change analog input mode in channel wizard
I am trying to configure analog input channels through the DAQ Channel Wizard but I can't seem to change the analog input mode.  The box is greyed out and set to "differential" mode.  I do not want differential measurements.  I want to change it to RSE or NRSE (not sure which one yet).  I have a PCI-1200 DAQ board and using ACH0, ACH1, ACH2, and ACH3 along with AGND wiring.  Any help will be greatly appreciated.
(2,748 Views)
Hi Lindy,
Check out this KB: Why Can't I Change the Input Mode for My Virtual Channel in MAX?. I believe it answers your question. You can set this configuration for all channels programmatically though. Check out the Tradtional DAQ user manual for help on the AI Config vi/function.
Hope this helps,
Andrew S
(2,725 Views)
