Can't communicate with IOTech Strainbook ethernet device
 I am trying to use LabView 8.0 to run a IOTech StrainBook module.  The StrainBook is connected to a laptop with a crossover cable.
I am using the LabView VI's that come with the StrainBook but I keep getting an error that the device cannot be opened.  One of the example VI's is called "Locate Device by Serial Number" but when I input the serial number for the device it says it can't open the device.  If I input a 0 for the serial number, it says it can't find a device with that serial number but it lists the serial number for my device as a device it did find.  Does anyone
have any experience with the IOTech StrainBook?  Thanks in advance.
Message 1 of 1
(2,261 Views)
