Can't connect to cRIO 9074 in MAX
I can't connect to a cRIO-9074, using MAX (LabVIEW2016).
What happened before: Adding software to cRIO with MAX, Cable disconnected during the process, Format
Now, Console Out shows IP 0.0.0.0.
How to connect, using MAX?
Note: The FPGA application is working (USER1 LED flashes as programmed)
Message 1 of 8
(5,873 Views)
Thank you for posting on the NI Forum.
Can you have a look at the following article that might solve your issue : http://digital.ni.com/public.nsf/allkb/ABE4BC247E8AC9BC8625734E005CAB42
Best Regards
Message 2 of 8
(5,813 Views)
Thank you, s_ipour.
I still can't connect.
MAX Troubleshoot Remote System Discovery crashes (attached pictures).
I can't ping IP 0.0.0.0.
Do you have any suggestion?
Best regards.
Message 3 of 8
(5,810 Views)
Hi raposo,
I think information at page 10 of this manual may help you.
Emre
Actor Framework rocks!
Emre TUZUNER
Message 4 of 8
(5,758 Views)
Hi, etuzuner.
Thank you, but I still didn't solve the problem.
The part number begins with 192172.
Console out shows the IP address is 0.0.0.0.
MAX still doesn't see the cRIO.
Console Out shows "Cannot open "/c/ni-rt/system/vxWorks".
Is this OK? (I formatted the cRIO)
Pedro
Message 5 of 8
(5,747 Views)
What's the current setting for your dipswitches?
Message 6 of 8
(5,724 Views)
Hi Pedro,
natasflw is right, can you tell us DIP switch configuration? Proper position should be told in the manual.
Emre
Emre TUZUNER
Message 7 of 8
(5,712 Views)
At the moment, all DIP swtiches are ON, except "USER1".
The problem started after formating the cRIO (IP 0.0.0.0).
I could connect before.
I could connect to an identical cRIO, after the problem. So, I am sure the problem is not on my laptop/virtual machine.
I was "forced" to format the cRIO, after a power loss when performing "Add Software". Can this harm the cRIO?
Message 8 of 8
(5,669 Views)
