09-23-2011 09:30 AM
I have LabView 2010 Pro Dev. Suddenly I can't display or access the functions pallet. I can get to the controls pallet.
Solved! Go to Solution.
09-23-2011 09:34 AM - edited 09-23-2011 09:35 AM
How are you trying to access it? Maybe it is in an offscreen location? What happens when you right-click on the diagram?
09-23-2011 11:48 AM
I have a dual monitor system but it appeared on neither. I tried deleting the Labview.ini file but that didn't help. When I right clicked on the block diagram viola!
Thanks.
09-23-2011 12:11 PM
Then mark Altenbach's message as the solution to your problem as he is the one who told you to right click.
09-23-2011 12:24 PM
I don't see how a viola solved the problem, but if he's happy...![]()
