Can't find Application Builder after installing AB 7.0 in a LabView 7.1 system
Hello, I just installed applivcation Builder 7.0 on my windows desktop (XP, SP2) that has already installed a Labview 7.1. But nothing happens...I just can't find it. Not on "Werkzeuge" (Tools) or anywhere else in the application.
Only in the explorerI can find Labview7.0\Applibs...
I reinstalled it 3 times now...what else can I do ?
or does the Application Builder 7.0 not work with LV 7.1 ?
any help would be appreciated
regards
fluxgate
(2,473 Views)
No, it does not work. You need the 7.1 app builder. If you had purchased the 7.0 app builder separately (and not as part of the profession version), when you did the upgrade to 7.1, you should have requested the 7.1 app builder. Since 7.1 is no longer sold by NI, I'm not sure how you can get the correct app builder. You should contact NI directly or your local field engineer.
(2,470 Views)
