Can't find DAQmx Write.vi
@RavensFan wrote:
Install the DAQmx 15.0 drivers again.  Check to make sure that support for LabVIEW 2014 is checked within the installer.  It should have been automatically the first time you installed it (assuming that you already had 2014 installed.
Perfect, it worked. Thanks you
Message 11 of 12
(804 Views)
@Gregory wrote:
Hi MS2010,
Is it possible that you have DAQmx 15.0 drivers installed for run-time but not for development? If that is the case, re-install the 15.0 drivers, this time making sure to enable development as well. That would explain why it says a "newer version is installed" but does not find the VIs when opened in LabVIEW.
Hi MS2010,
Please do read our responses carefully so that we do not chase our tails in circles.
Message 12 of 12
(798 Views)
