Can't find cRIO on my computer
I am using a cRIO 9004 CompactRIO Real-Time Controller with NI9401 module in my school's lab. I am not sure if this is the first time this compactRIO installed on this computer. I connect the cRIO to computer by crossover cable and I can find it in the Measurement & Automation Explorer as shown in 'MAX interface' and 'MAX interface2' screenshots. The status there shows the cRIO is connected but the parameter like the 'System Start Time' is unavailable. Also, I cannot find any device under the 'Devices and Interfaces' option. I cannot expand the Software option under the Remote Systems option and the MAX is not responding when I click the Software button. I also try to build a new project and set the cRIO as device, then I find the problem shown in the 'New Project' screenshot I attached below.
Does anyone know what happens there. I am really new to LabView and NI devices, your help will be critical for me.
(4,135 Views)
I would recommend uninstalling the cRIO driver and reinstalling it from our website. Also, I would suggest taking a look at the Getting started guide for CompactRIO. Page 3 of the guide indicates the software required to use your cRIO. I would recommend taking a look at that. I am linking the getting started guide below.
Link: Getting Started with CompactRIO and LabVIEW
https://learn.ni.com/learn/article/getting-started-with-compactrio-hardware-and-labview
Shezaan Noorani
(4,101 Views)
Hi, Shezaan,
Thank you for your reply. Yesterday I figured out the problem was the device IP address didn't match the PC's ipv4 address. With that solved, I finally could find my cRIO. The next problem is to install all the drivers I need, so your link will be very helpful.
Best
(4,095 Views)
http://www.ni.com/pdf/manuals/372596b.pdf
I could not find the document can anyone help me to find this
(2,151 Views)
Can you check if this is what you're looking for?
https://www.ni.com/docs/en-US/bundle/ni-xnet/page/nixnet/gettingstartedwithcompactrio.html
Jenny B
NI Community Support
(2,105 Views)
