Can't find the "Run" option !!!
I have a problem ...
I have a project ( One Main Vi and some SubVi's and Sub SubVi's ) which
doesn't have any Errors in it but i can't see or find the option
of "Run Vi" !! ( You know, the white Arrow that use to Run the main
Vi ) , also in the "Operate" option in the menu, the "Run" option and
the "Stop" option are Disable !!, but instead i can run it step-by-
step !
Why does it happen ? why can't i see the "Run" option ? should i change
something in the configuration in order to see it ?
Also, i don't know if it's have anything to do with this, but at first
this main Vi ( Top Vi in this project ) had a "Broken" Arrow becouse
some SubVi's where missing, but after a fixed it and i found all the
missing SubVi's,
then suddenly the Broken arrow was gone, But No
White "Run" Arrow was display instead of the broken one !!
Please answer as soon !
Best regards
Noam.
Sent via Deja.com
http://www.deja.com/
(3,091 Views)
You can modifie the properties of the Vi in "file/properties of the Vi" :
you have to go in "window appearence" and so select "personnalization" and
put True to "visualize execute button".
I hope I can help you,
noam_opsigal@hotmail.com a écrit :
> Hi,
> step !
r to see it ?
> missing SubVi's, then suddenly the Broken arrow was gone, But No
> Best regards
> Noam.
> Sent via Deja.com
(3,091 Views)
In article <95m6mk$k39$1@nnrp1.deja.com>,
noam_opsigal@hotmail.com wrote:
> Hi,
which
> step !
change
> some SubVi's whe
> Best regards
> Noam.
> Sent via Deja.com
You can "right click" on the "icon" or "connector" of the vi in
question and select window options/execution options one of those
choices has an option of hiding the run button.
Sent via Deja.com
(3,091 Views)
Thanks !!
wrote in message news:95nq5q$4ki$1@nnrp1.deja.com...
> > Hi,
> which
> > step !
> change
> > Best regards
> > Noam.
> > Sent via Deja.com
> Sent via Deja.com
(3,090 Views)
