Can't generate signal over cRIO over ethernet
i just want to generate a signal//output voltage over the network.  i have been having much trouble both reading/writing to the cRIO 9014.  its recognized in MAX. once i set the ip address i can see and deploy the modules i have hooked up.  i tried creating a physical channel but labview could not see it, even when written the link to it manually.  i have also tried shared variable and global variables.  but i can't excute and function or read any data.
(2,857 Views)
just an idea,
maybe you can use Current Value Tables of labview, and CCC to get the communication by the network.
I have seen it beeing used by somebody that came to assist me. And I must say he got it working pretty fast and it worked pretty good...
When you are using CCC you also need the Tag Configuration Editor to link the Tags.
I haven't tryed it out myself so far to build it.
I only tested the use of CVT's. And that worked pretty good.
Hopefully this can give you some help.
________________________________________________________________________
Problems will keep comming... Lets hope the answers do that to.
Never give up without a fight...
(2,836 Views)
just an idea,
(2,836 Views)
You have your timed loop to run every 1000ms and the simulate signal to output 1000 samples.
The AO2 Shared variable output only outputs ONE point at a time. Notice the coersion dot between the dynamic data wire and AO2's input. This means that the signal is coerced into a single point.
Try changing the DT of the timed loop to 1ms, and setting the simulate signal to generate one point at a time. Note that this loop rate is fairly fast but should work.
Good luck,
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(2,811 Views)
