Can't get Win2k/NT/XP service working
I am trying to create a service and have followed the example here:
http://zone.ni.com/devzone/conceptd.nsf/webmain/A9B2FA96B851394586256B26006ECB98?opendocument
This question may actually be more related to VI server's however, I'm not sure.
I have recreated the files per the tutorial. In the GetCookieClient VI, with the CookieService program running in the background, I can successfully execute and get Fortune of the Day, so long as I replace the "myserver.natinst.com" with "Localhost" or "127.0.0.1"
My problem is trying to use my actual machine name, so that this code may actually be used across the network. I am at a loss why I cannot use my Host Name or IP address with this code... below is a summary of my re
sults:
"Localhost", "127.0.0.1" -- Works
Resolved IP from IPConfig -- Error 63, The network connection was refused by the server.
Host Name from IPConfig -- Error 66, The network connection was closed by the peer.
Host Name + Connection-specific DNS Suffix - Error 66, The network connection was closed by the peer.
If I resolve "Localhost" to an IP, then the IP back to a string (using the LV network functions), I obtain the Host Name + Connection-specific DNS Suffix.
Any ideas why I can't just plug my machine name in and have it work?--why it wants "Localhost" or "127.0.0.1"? I would eventually like to try calling my service from a different PC, but if my own PC can't even access itself... well... I don't think I'm going to get very far elsewhere.
(2,700 Views)
> not sure.
> my results:
> by the peer.
> very far elsewhere.
Have you made sure to enable other IP address ranges in the VI server
section of your application ini file. I believe that by default VI
server only accepts local connections and evethough you are using your
own public IP address, this is not really a local address in the most
strict sense.
To add other IP address ranges you can best go in LabVIEW into
Options->VI Server and add them there and then copy those entries from
the LabVIEW.ini file to your application service ini file. It is not a
good idea however to add full access to * to this list if your computer
is possibly accessible from public internet.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,700 Views)
It's on an internal network and I'm just testing out creating services. Current properties on the CookieService are:
I will go back and attempt to add specific flavors there and see if it recognizes things.
(2,700 Views)
