Can't get additional decimals from a double numeric
I tried passing a number with 6 decimals through a double numeric. But only two decimals are being passed. I examined settings for the numeric, couldn't see why this happened.
Your suggestions are appreciated.
(2,751 Views)
Accepted by Anne_Z
Wire a suitable format string to "write to spreadsheet file" to show more decimal digits.
Note that the orange wire always contains the full 64bit of information. The formatted decimal display is just cosmetic.
(2,743 Views)
That did it. Thank you very much.
(2,716 Views)
