Can't get signal from DAQ card
Our macintosh system crashed and was just repired. Now labview can run but our DAQ card NBGRIB/TNT can't get any signal at all! I tried to run Ni-daq command and inside I can find DAQ card. When I double clicked it, it is said" No I/O connector diagram is availabe for NBGRIB/TNT".
Thanks in advance.
(2,561 Views)
Hi, if i'am correct either the drivers need re-installing or that the the drivers are installled correctly, but labview is not recognising that the daq is installed, thats why u get no i/o connector diagram. The easiest thing to do would to re-install the daq so that the labview recognises the daq again.
Stuart
(2,561 Views)
