Can't import CAD model (.wrl file) into Robotics Simulation builder LabVIEW
Dear LabVIEW users,
Actually i was seeking to import a cad ( assembly) file from SolidWroks into LabVIEW through
"Robotics Simulation builder". However it prompts out a massage which said " the converter can not load the input file correctly". However i have tried to use the CATIA to generate .WRL cad file, it works but i still can't see the 3D model in the Monitor screen.
Please check the screen shots below.
Thanks.
Best Regards.
(2,823 Views)
It sounds like there is a problem with the file formats, have you tried something simple like a basic geometric shape? Maybe the WRL generator in SolidWorks produces incompatible wrl code. If that works, how about a simplified version of what you are trying to import?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,762 Views)
