Can't install (unzip) - "Zip Damaged... Bad CRC. Possible cause: file transfer error."
I'm trying to install Labview. I am a student and chose to download as professor/student.  The executable downloaded, but when I run it it says,
"ZIP damaged: file C:\National Instruments Downlaods\LabView English\2012\Products\LabVIEW\Part12\Part12.cab: Bad CRC. Possible cause: file transfer error."
This is from my 2nd download of the downloader and executable.  The first time it stopped at Part06.cab.  I was able to install on my laptop with no problems, but ran into this error when trying to install drivers for the NI USB-6008.  My laptop is Windows 7 32-bit. My desktop (on which I'm currently working) is Windows 7 64-bit.  Please help me figure out how to get this program running. I've tried running as administrator and that's made no difference. Thank you.
(8,160 Views)
Can you download it on another machine and try to unzip it on that machine? It it works, at least you could rule out a corrupt file or transfer problem.
(8,155 Views)
