Can't load .NET properly in window 10 for labview 2014 and later
I am having a problem that is seem to be no answer or properly answer to the issue.:
I have a .NET dll that is called by Labview.  This have no problem what so ever in window 7.
  How ever since I switch to Window 10 I encounter several problem.
1./ The NET dll can be loaded and run properly in any Labview  version from 2014 to 2019.  But it must included in a project.
2./ The .Net can not be loaded and get an error when run a stand alone vi that  called directly the dll without putting the VI in a Labview project.
3./  When build the executable from said project in case 1.  The executable return and error as: "The VI is not executable.  The full development version of labview is required to fix the error"
4./  Create a Labview.exe.config file to force the CL version 2 to load did not help
5./ All the Microsoft. NET version appeared to be present.
6/.  The only way is working that you have to run said Vi in a project and  building executable or installer does not work.
I hope that I get get a definite answer to the problem.  It seem to me that .Labview .NET calling function is very buggy and unstable.
  I have been trying in several Window 10 machine from fresh install to fully upgraded.  They all have the same problem.
This wasted a lot of time and my company have been using thousand off license for labview.  Hope that we don't wasted money too.
Tphan
(2,679 Views)
I sense frustration. However many people have not had a problem (myself included and I do a lot of .NET integration in LabVIEW). Some tips:
  • Always use a LabVIEW project for .NET integration (dev environment)
  • Always include assembly dependencies in the project (unless they are in the GAC / just the framework). This helps with the next point.
  • When building an executable, ensure the assemblies and dependencies are specified to be copied to the output folder
There are a lot of generic answers for what you have described - mostly because you have not given us enough detail to work with:
  • What is the .NET assembly? A third-party or one you are developing yourself? The fact that your reaction differs between stand-alone VI and project implies that the assembly may have other dependencies.
  • VI example with the .NET assembly attached? So we can attempt to replicate your problem.
  • What .NET Framework does the .NET assembly target? You say your OS is Windows 10 - have you installed the .NET 3.5 SP1 framework (in order to get CLR 2.0)?
(2,655 Views)
Here is everything I tried.  zip it up it kind of big.  3 thing I do:
-Load .Net in stand alone: error.
-Load net in a vi From a project: Works
-Build executable fro project: failed to run and broken vi.
  Note that I have evry thing work fine in window 7.  Just when my company switches to Win 10 the everything fail.
The DLL has been use in many other application for C++, Tickle, C$ and many other languages.  They all work fine in Win 10.
  except Labview
THanks
Tphan
(2,640 Views)
Here it is the Files
Please see to your heart content.
Tphan
(2,637 Views)
