Can't log data into multiple column *.csv format
Accepted by topic author Anh_Tran
So here's the deal.  In the Beginning, NI created LabVIEW to help engineers get Data from hardware and write programs to acquire and analyze these data.  The data often came from "instruments" (hardware) that had very accurate clocks and "did the sampling" very accurately, better than the PC could do (what with Windows multi-tasking and trying to "be the boss".
At an early stage, NI created the Waveform data type for sampled data.  This had two Time parameters -- t0, the (very precise) TimeStamp when the first point was acquired, and dt, the (very accurate and precise) sampling interval that said how much time there was between samples.  Note that with just these two numbers, you don't need to store all of the times data were sampled -- it is easy, fast, and (space-) efficient to compute these times "on the fly) (t0, t0+dt, t0+dt+dt, ... t0 + (n-1)*dt).
Just over a decade ago, NI came up with a much-improved way of programing hardware, DAQmx.  About 5 years later, they invented the Dreaded DAQ Assistant (I suspect because DAQmx was too complicated for their Sales Reps to demo how easy it is to collect data with LabVIEW).  They also invented the Dynamic Data Wire (don't get me started ...).  I recommend not using either of these!
So here are some suggestions:
  1. Start your Spreadsheet with a "reminder", say a string "dt = 0.001"
  2. If you have 2 channels of N data points, write a 2D array without transpose, 2 rows, N columns.
  3. Write a blank row between such samples to distinguish one "chunk" of data from another.  Note that when processing the data, you should be able to figure out when to "skip a row" (or when a row is empty, possibly all zeros).
Here's some code to try.Example Delimited SpreadsheetExample Delimited Spreadsheet
Bob Schor
Message 11 of 12
(880 Views)
Your explanation of t0 and dt is on point! Thanks for that.
I do enjoy your history lesson too. Keep being you Bob. You knights are freaking amazing.
Message 12 of 12
(857 Views)
