Can't open database connections after building stand-alone application
When using the database connectivity toolkit in LV 7.0 I can connect to ODBC or OLE data sources and use them without a problem. Once the stand-alone application is built I get the following error for ODBC.
DB Tools Open Connec (String).vi->test-db-app.viException occured in Microsoft OLE DB Provider for ODBC Drivers, [MySQL][ODBC 3.51 Driver]Can't connect to MySQL server on 'neuromancer.uky.edu' (10061). in DB Tools Open Connec (String).vi->test-db-app.vi
or for OLE:
DB Tools Open Connec (String).vi->DB Tools Open Connec (Path).vi->test-db-app.viException occured in Provider, Unspecified error. in DB Tools Open Connec (String).vi->DB Tools Open Connec (Path).vi->test-db-app.vi
Anyone have any ideas?
Thom Coates
(2,985 Views)
Hi Thom,
A quick way to narrow this problem down is to try connecting to an Access or MS SQL database on your computer. This will remove MySQL out of the picture and will allow us to make sure that the code in LabVIEW is written correctly.
Please let me know how this goes.
Feroz
(2,985 Views)
Thom,
I built an application from a VI that I use to communicate with mySQL and it worked just fine. Did you make sure to define the connection on the target computer (ie, use ODBC Administrator to define the DSN or include the *.udl file with the project and verifying the connection worked)
What OS is your target machine? If it's Win9x or NT, then MDAC isn't included with the OS and you need to install it separately. Chapter 6 of the Database Connectivity Toolset User Manual describes how to do this.
(2,985 Views)
