Can't open project
Hey my labVIEW doesn't work anymore and i can't open my project can sombody please open my project and take some  screenshots so i can explain my code in my worktask
Thank you in advance,
Seppe Pairon.
(3,577 Views)
Yikes.  I have a feeling your problem is the VI is using too much block diagram space.  You need to learn to use a State Machine and a Producer/Consumer.  Your abuse of local variables will cause problems.  Using a queue to pass the data to your second loop will help clean a lot of that up, make it easier to figure out, and easier to debug.
(3,539 Views)
can sombody take smaller screenshots and higher quality it is for my script for school.
(3,521 Views)
Attached a PDF printout that is probably the best thing you are going to get.
And I see that you have made some tidying efforts from the previous version but made no real substantive changes since this thread.
Good luck with the review.
(3,492 Views)
