Can't open serial port
I don't know what I've done.
When I try to open COM1 I get:
"Error -1073807202 occurred at Property Node in VISA Configure Serial Port (Instr).vi->Untitled 1
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input."
"VISA FInd Resources" reports 0 resources found.
any ideas?
(4,855 Views)
Have you installed NI-VISA?
(4,849 Views)
I thought I did.
How do I check?
(4,845 Views)
It should show up in Measurement and Automation Explorer (MAX) click the Software folder to expand it, then click on NI-VISA. It should show the versions installed in the right panel.
(4,834 Views)
Try to open the port using Windows Hyperterminal and see if you get an errror.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(4,827 Views)
