Can't print to network printer after application is built
All computers are Windows 2000, LabVIEW 5.1.1. While the application is run from Labview, printing to a network printer works fine(using the Easy Text Report.vi). The application was then made into an exe using the application builder. The development system was removed from the computer and network printing still works ok. When the exe is installed on a different computer (along with AccessHW and CVIRTE5.5) network printing does not work from the application. Other programs on this computer can do network printing.
It appears the development system has installed some files that are retained even after the development system is removed. What am I missing.
Tom Radford
twradford@hydro.mb.ca
(2,689 Views)
Did you create an installer and choose to include NI Reports Installer on the Advanced settings? NI Reports uses an ActiveX component that must be installed.
(2,689 Views)
