Can't read RTC in deployed application on cRIO9022
I have built a datalogging application that saves data to a filename of name = current date/time on USB drive. This works fine when connected via network to the development computer, however, when deployed as a startup VI, the date and time section of the filename are missing, as if it can't read the RTC. The file creation time parameter of the file is correct.
any suggestions ?
thanks.
(2,911 Views)
Hi can you show us the relevant portion of your code?
Marco
(2,908 Views)
Here it is.
...can't recall why I  write the indicator and set it's value by variable- the dangers of not documenting as one goes...
(2,891 Views)
Accepted by topic author JPP
Think I have found it. When deployed, the front panel indicator ceases to exist.
http://digital.ni.com/public.nsf/allkb/FC5024A5DD6344C886256C8C0054689B
(2,882 Views)
Hi JPP,
if you want you can mark the issue as solved (by yourself 😉 )
(2,855 Views)
