Can't read data from Tektronix TDS 224
I have 3 Tektronix scopes hanging off a PC via GPIB. 2 of the scopes are TDS 220 and the third is a TDS 224 (4 channel version of the 220). I am using the NI instrument drivers available. I can read both channels of data from the 220s and channels 1 and 2 from the 224, but I can't seem to read channels 3 and 4.
The NI instrument driver is labelled as covering the 224 (on the NI web site), however once it's loaded all the VIs are labelled as 2X0, none are labelled as 2X4. This gets me wondering as to whether they are set up to only read channels 1 and 2.
Any suggestions? Thanks.
(2,878 Views)
OK. Ignore the above. I found the problem, and it is I!
(Cut and paste code and forgot to update channel numbers). Duuuuuh!
(2,878 Views)
