Can't remove a polymorphic VI from a missing lvlib
Normal VI's have a File > Disconnect from Library menu item, but polymorphic VIs don't. If a poly is part of a lvlib, and the lvlib is deleted, the poly is broken with a "This VI is connected with a library that LabVIEW cannot find. Find and load the library or select File»Disconnect from Library" message. I don't have the original lvlib, and there's no File > Disconnect from Library menu item - how do I fix my poly?
Workaround: save it under a new name - the new copy will be disconnected from the lvlib.
Copyright © 2004-2026 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(4,960 Views)
Another work-around might be to create a new lvlib, add it, and then disconnect it?
Just a thought.
Bob Young
(4,931 Views)
Thank you for the report.  With your workaround, you must select the "open additional copy" option on the save as dialog.  Bob's workaround works as well.  This was reported to R&D (# 118218) for further investigation.
(4,903 Views)
Great - thanks Jeff.
(4,879 Views)
Accepted by topic author crelf
I was just starting to look into fixing this, and discovered it was already fixed in 8.6.  Thought I'd pass along the info.  Enjoy.  🙂
(4,690 Views)
That's great news - thanks Jeff Robot Happy
(4,669 Views)
