Can't rename can chassis in MAX (9188XT)
Hi community,
I am unable to rename my NI 9188XT chassis under MAX. I can change the hostname, but not the actual device alias. Its not a name conflict as I can not rename it to anything, whatever I type it changes back to cDAQ9188XT. I have restarted the unit several times. A screenshot is attached.
Any reason behind this?
thanks!
(3,506 Views)
Hi 1984
Are you saving the changes when you change the name?
Regards
(3,446 Views)
Hey,
as I said, the hostname can be changed, the alias on the left can't. Whatever I type it changes back to the original name. I cant save the changes because I can not change the alias.
thx.
(3,442 Views)
I have the same problem.
I don't like to leave the default name in case I change chassis to run the same  program. I would have to reconfigure max.
JCollado
(3,364 Views)
