Can't reset digitizer
I can't init my digitizer again after first run of my .vi
I am not sure if it crashed, because the self test in MAX still works, but the NI Scope Soft Front panel can't init either.
Error: -1074097145
niScope Initialize With Options.vi<ERR>The requested operation did not complete in time.
Device: OSCILLOSCOPE
I cant reset my chassis using MAX because it says I dont have sufficient user rights.
There is no reset option for my digitizer. Reboot doesn't help. Only shutdown helps.
What I try to achieve is start sampling on my digitizer, when generator started.
Chassis PXIe-1095
Gen PXI 5411
Digitizer PXIe-5172
Actor Framework
Message 1 of 1
(896 Views)
