Can't save vi because an input parameter is invalid. The VI is U8 in = U8 out, basically no code.
I installed an earlier version of LabVIEW yesterday, LabVIEW 2022 (64bit) Windows 11.  I was trying to do some things but I'm having errors so I created a really simple VI that just has a U8 numeric input and I wired it straight to a U8 output.  I can't even save the VI because "LabVIEW: An input parameter is invalid.  For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.  I even deleted everything from the VI and still can't save it because I get the same error.  What input parameter could it be referring to because I don't have any inputs because it's a completely blank vi.
(1,383 Views)
NI Product Compatibility for Microsoft Windows 11
The first supported LabVIEW version in Win11 is 2022 Q3. Any unsupported versions are not validated and might behave incorrectly.
https://tmesystems.net/
(1,347 Views)
Your VI is in "NI.LV.PlugIN" ?
George Zou
(1,314 Views)
I figured out it was something wrong with my template.  I have a 43" 4k monitor and when I create a new VI the window size is about 24", which is huge, so I found a way to use a template to set the default to a more reasonable size, for me.  https://forums.ni.com/t5/LabVIEW/New-VI-default-window-size/td-p/3664093 But it's not working I guess.  When I create a new VI from New... and select blank VI the problem went away.  I couldn't save because the path for the save/save as locations was "not a path".
(1,307 Views)
